0 members (),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hi guys,
I've had several people now tell me that my truck smells like its running rich, and it gets some nasty mileage too, I think (310 kms per 60 liter tank). So I tried to adjust it...I have the shop manual, and it suggests I get an RPM guage and a vaccuum guage. Says the rpms should be at 460 (i think, have to check it again) at idle, and I hook up the vaccuum guage before ajusting screws. Then I adjust mixture screws until I get the correct vaccuum reading ( had this listed too) I don't have either guage, so I winged it by ear. I have a few questions though, the two mixture screws, is right lean and left rich? and where do I hook up the vaccuum guage? I saw a small outlet on the back of the carb, with a rubber plug on it. Is that where? And if I was to get an RPM guage, where would I hook that up? By the way, the engine is a 283, and the carb is a Rochester 2 barrel. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | The two screws you are talking about are only for the IDLE system and will not affect you mileage one bit. Sounds like you might be in for a carb rebuild. Is the choke working that is does it open completely when warm? | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | While a tach and vacuum gauge are nice to have, untold thousands of engines have been tuned "by ear". Turn both idle mixture screws in (clockwise), gently, until they bottom out, then back them out 1 1/2 turns each. That should be a good starting point. Warm up the engine fully, choke all thre way released, and adjust the idle speed screw on the throttle linkage to get a smooth run- - - -speed isn't terribly important right now, but don't overdo it on RPM.
Now- - - -turn the idle mixture screws clockwise, one at a time, until the engine starts to stumble (too lean). Back the screw out again until you get a smooth idle. Repeat with the other screw. It might be necessary to do this several times to get things just right. Finally, adjust the idle speed to whatever curb idle suits your preference.
Once you get the engine speed a little above idle, none of the above adjustments have any effect whatsoever on fuel mileage or rich/lean condition. Cruise or high speed mixture is controlled by the main jets and power valve, and they have no adjustments other than changing jet size. If it's running way rich, check for a stuck power valve. Jerry
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Sounds about like what I did, but will tinker with it again I think. I believe the choke is working as it should, it is manual, so I have to open it myself when the engine is warm.
Took the truck for a burn down the highway tonight after adjusting it, seems to run better and have a bit more power now. Not sure why...But yeah, the fuel mileage, I wouldn't be too suprised if it's normal. Nobody ever said 50 year old trucks were fuel efficient... | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Would pretty much agree with Jerry (Hotrod Lincoln) except would start with 1 turn instead of 1 1/2 on pre-smog (1968) carburetors.
And 310kms per 60 liters is about 14 1/2 miles per gallon - not too bad.
Check your tires for proper inflation, and also check to make sure you do not have a brake that is dragging.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The ignition must be set before doing any mixture adjustments.
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Agreed...when was last tune-up? If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
