| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 9 New Guy | | New Guy Joined: May 2004 Posts: 9 | Need help how to use a carburetor flow meter on my 216eng. one barrel carburetor. the instructions not to clear on how to set up and what to adjust. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | If you are talking about the deal that sits on top of the carb and measures the air flow forget it .They are used for balancing multiple carbs and wont do you a bit if good. | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | If you have only 1 carburetor, retired wrench is absolutely correct! If you trying to synchonize two or more carbs on a single engine; try this link: http://www.thecarburetorshop.com/Dual1barrelcarbs.htmOR give me a call at 573-392-7378 (9-4 Mon-Wed central time). Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
