4 members (wilbur53, burgundybolt, Jack Ryan, 1 invisible), 86 guests, and 3 robots.
Topics128,086
Posts1,056,331
Members48,442
I am so frustrated. Sorry for posting this here but i am out of ideas and I really need help! After two days of trying to figure out what is wrong with the brakes on my 46 stylemaster I have just about had it. Bought NOS Wagner wheel cylinders to replace the leaking ones. Well the fronts went in and adjusted just fine but the rears are fighting me.
Basically, The old brakes were adjusted fine. As soon as I took off the spring to slide away the shoes to get the wheel cylinder out my problems began. Put the new wheel cylinders in and I have a tremendous gap between the pads. I tried hammering the pads, squeezing them together and they just refuse. If you bang one side closer the other side just moves further away. The E-brake cable is loose... I tried extending the posts out on the wheel cylinders to accommodate the space between the shoes but the pads are out so far I can't get the drums on. WTF happened?
Here's some pics. Tried turn that essentric bolt... did nothing....
PLEASE HELP!
http://i142.photobucket.com/albums/r97/BG528/46Stylemaster009.jpg
http://i142.photobucket.com/albums/r97/BG528/46Stylemaster010.jpg
1946 Chevy Stylemaster Sedan - 216 6 Cylinder
1971 Chevelle SS
1995 Monte Carlo Z34
2005 Corvette Z51
Hard to see in the pictures but did the E-brake crossbar slip out of position? That's a common hold up on newer brakes.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Riding in the Passing Lane
The most likely thing is the emergency cable is stuck & not going back. Try prying back on the lever that the cable hooks to. You dont have much lining left there.
1972 Chevy c10 Cheyenne Super
3B Offline
Hy Danspeed1, I agree with Wrenchbender Ret. it looks like the emergency brake lever is well out from behind the shoe it is hinged to, and the spring on the relay rod to the other shoe appears to be fully compressed. The only other thing I can think of is, have either one of shoes slipped behind the edge of the backing plate, try lifting them away from the backing plate and see if they move closer togethr then, hope that helps.
Thanks for the tips guys,
I pryed on the ebrake lever and it did take up some of the space between the wheel cylinder. I also moved that eccentric bolt and it did move the pads a little closer yet. Then I turned out the bolts on the wheel cylinder out to adjust the pads. Seems like the bolts are pretty far out now to adjust the pads, but then a again my brake lining is kind of low. Thanks for the help,
Dan
1971 Chevelle SS
2005 Corvette Z51
