2 members (Simon1954, KingG),
56
Mod | | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I'm in the process of striping my cab down,a little hear and a little there when I get time.My local paint store suggested epoxy primer on the spots until I get the entire thing done,but this seems like a lot of trouble.They said the epoxy must be removed before any body filler can be applied.I'm a novice so I'm looking for the best/easiest way.Any advise would be appreciated Thanks.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | I was doing the same and just went ahead and used por-15 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are well-known and high-quality epoxy primers that allow body filler to be applied over it (as long as appropriate procedures are followed). This is very commonly done during restorations.
What brand of epoxy primer are you using?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Once POR has cured, it can be painted-over, but cured POR has to be tediously and carefully prepped for over-coating. POR recommends covering it with a primer that is applied before the POR layer cures (I have successfully used an PPG DP epoxy).
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I'll probably be using PPG products.I guess I will get the entire cab stripped before I use POR 15 and epoxy primer.Just worried about the bare metal waiting to be sealed.
| | | | | Joined: Apr 2010 Posts: 5 New Guy | | New Guy Joined: Apr 2010 Posts: 5 | I'm no expert, but I used Omni epoxy primer over bare metal. It sticks good, seals the metal to prevent rust, and in some places I used some filler over the epoxy with no troubles. It's a medium cost primer, there are probably better more expensive epoxy primers out there. It's not really a primer you will be able to sand much, it gets pretty hard. You can read the spec's for it online, or just google it.
If you aren't going to paint over it right away you will probably need to scratch coat it before you cover it with primer/paint later.
I also used a high build primer in areas that had some pitting, sanded down to fill the pits. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | May I ask why you are using POR 15 as the first coat? If you have some rusty areas there are other products that are much easier to use under the same circumstances. I used EASTWOOD RUST ENCAPSULATOR. It's thinned with lacquer thinner, sprays easily and can be used under any primer. But that's just my opinion based on my personal experience. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | If you are just looking to cover the bare metal and intend to go back in and grind it off and do body/metal work, then I would not spend the money on epoxy. If you have your project inside, then a regular/cheaper primer should work to cover for a month or two. As you know,the non epoxy primer will allow moisrure to penetrate to the metal and then you are back to rust city, so keep it in the shop. | | | | | Joined: Jan 2007 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 93 | If you are keeping the cab dry in a garage, the other option is to use phosphoric acid on the bare metal. The phosphoric acid (brands such as Ospho) are misted on with a pump up sprayer, scuffed with a scuff pad, then wiped with a paper towel. The surface of the metal won't rust after this application unless it gets wet. When you are ready to primer or bondo, you scuff the surface with scuff pad or sand paper before cleaning and priming or bondoing.
One caveat with using phosphoric acid is not to use an etch primer or epoxy that contains acid when you coat it, otherwise you can have delamination issues.
I live in New Orleans with high humidity and this still works well for me for parts that are stripped and in the garage waiting final body work and paint.
I hope this is helpful. Regards, Steve New Orleans | | |
