8 members (Oswald, Bill Hanlon, Hanks custodian, gswbbc, cmayna, Otto Skorzeny, oldsteve, Stovebolt48),
129
Mod | | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 14 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 14 | It's both, as it turns out!
We bought this truck with a recent V8 installation and rewire, among other things. The engine would run 5-8 seconds after turning the key off. Another post on this forum indicated that the electric cooling fan could act as a generator and cause this issue.
The person who rewired the truck did a pretty good job, but had all switched circuits powered through one fuse and connected directly to the ignition switch. This had already caused the engine to lose ignition power when a turn signal wire shorted.
I added another fuse panel and powered it from the ignition switch. Now I have fuses for individual circuits. I also installed a relay for the cooling fan with power taken from the hot fuse panel and control power from the ignition switch. Now the engine shuts down as it should. I looked into simply adding a diode, but when you get above 10 amps they start to get expensive.
1953 3600 350/700R4
