1 members (UtahYork), 80 guests, and 2 robots.
Topics128,049
Posts1,055,637
#641439 04/28/2010 4:23 AM
Y
yar
Offline
Y Offline
Hey guys, do any of you know of a 12 inch Atlas/Craftsman lathe bed for sale. An old buddy of mine just gave my son a basket case, but well tooled lathe, but the bed is extremely worn right in front of the chuck. Somebody must have used it as a production machine making short bushings.
Thanks!
Ray
yar #641443 04/28/2010 4:33 AM
Try a wanted ad at http://www.practicalmachinist.com/vb/
a great site for machine shop stuff
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
yar #641454 04/28/2010 5:16 AM
Most work is done in first 12" away from chuck. Call a machine tool outfit and see if they can scrape the ways.
Dan Bentler
leitmotif #641528 04/28/2010 2:43 PM
Y
yar
Offline
Y Offline
Grigg and leitmotif thank you for the suggestions. I will pass them on to my son. I have not seen this lathe for about 30 years. Back then my buddy brought it home as a basket case. There was damage to the Morse 2 taper in the spindle. I repaired that by boring out the damaged part, inserting a thin sleeve and then restoring the taper with a Morse 2 reamer in the evening adult education machine shop class I was taking.
I recall the bedways being pretty bad. I suggested to my son that he find a machine shop with a huge surface grinder to regrind the tops of the bedways.
He's a "Rocket scientist" at Lockheed Martin Space Systems so what can an old geologist like me tell him?
Ray
yar #641532 04/28/2010 2:54 PM
Tell him to have fun with it..
I suspect a replacement bed/parts machine can be found for something similar to or less than professionally regrinding the ways. Worth looking at all the options before deciding what to do.
Grigg
---All pictures---
Grigg #641642 04/28/2010 9:57 PM
Look on ebay there a lot of older lathes with out quick change for not very much. I think the 10 " lathe bed might inerchange with the 12" as they share a lot of other parts.
ttodd #641755 04/29/2010 5:32 AM
Y
yar
Offline
Y Offline
Thanks ttodd. I actually have a 10" Atlas. I'll keep in mind that a 10" and 12" bed might interchange. Thank you for point that out. We have been checking ebay and will keep doing so.
Ray
yar #642353 05/01/2010 4:02 AM
A lot of those lathes have a bed that can be turned around, and the headstock, etc. bolts on in a mirror image of its original position. Worth a try, maybe.
Y
yar
Offline
Y Offline
Thanks for that suggestion Jerry. I will forward it to my son. He's a "Rocket scientist" at Lockheed so he ought to be able to figure out a way to put the lead screw bearing and the carriage rack on the opposite side if turning the bed around is an option.
Ray
Moderated by  MNSmith
