| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Hey guys, do any of you know of a 12 inch Atlas/Craftsman lathe bed for sale. An old buddy of mine just gave my son a basket case, but well tooled lathe, but the bed is extremely worn right in front of the chuck. Somebody must have used it as a production machine making short bushings.
Thanks!
Ray
| | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Most work is done in first 12" away from chuck. Call a machine tool outfit and see if they can scrape the ways.
Dan Bentler | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Grigg and leitmotif thank you for the suggestions. I will pass them on to my son. I have not seen this lathe for about 30 years. Back then my buddy brought it home as a basket case. There was damage to the Morse 2 taper in the spindle. I repaired that by boring out the damaged part, inserting a thin sleeve and then restoring the taper with a Morse 2 reamer in the evening adult education machine shop class I was taking.
I recall the bedways being pretty bad. I suggested to my son that he find a machine shop with a huge surface grinder to regrind the tops of the bedways.
He's a "Rocket scientist" at Lockheed Martin Space Systems so what can an old geologist like me tell him?
Ray
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Tell him to have fun with it.. I suspect a replacement bed/parts machine can be found for something similar to or less than professionally regrinding the ways. Worth looking at all the options before deciding what to do.
Grigg | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Look on ebay there a lot of older lathes with out quick change for not very much. I think the 10 " lathe bed might inerchange with the 12" as they share a lot of other parts. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Thanks ttodd. I actually have a 10" Atlas. I'll keep in mind that a 10" and 12" bed might interchange. Thank you for point that out. We have been checking ebay and will keep doing so.
Ray
| | | | | Joined: Feb 2004 Posts: 29,778 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | A lot of those lathes have a bed that can be turned around, and the headstock, etc. bolts on in a mirror image of its original position. Worth a try, maybe. Jerry
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Thanks for that suggestion Jerry. I will forward it to my son. He's a "Rocket scientist" at Lockheed so he ought to be able to figure out a way to put the lead screw bearing and the carriage rack on the opposite side if turning the bed around is an option.
Ray
