| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | I put a chevy 350 in my 58 apache. I purchased some hugger headers because I couldn't get anything else to fit. When I put the headers on, I had to hammer in the header a little bit so that it wouldn't hit the steering box.
Has anyone had any problems overheating their steering box? Should I put a reflective insulation around the steering box? Any advice on this would be appreciated.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | That would seem to be a good idea. My concern would be cooking the seal and causing a leak since they are not made to get as hot as a header would probably bake at. If you have a digital electronic thermometer take a reading and see what your up against.
| | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Thank you. I was thinking the same thing but didn't want to spend $15-20 if I didn't have to. | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Thank you. I was thinking the same thing but didn't want to spend $15-20 if I didn't have to. | | |
