5 members (Gdads51, jmoore, Steelonsteel, 66flea, kbenz), 107 guests, and 4 robots.
Topics128,087
Posts1,056,372
Members48,442
#642213 04/30/2010 7:53 PM
I'm wondering about using a vacuum booster with a 292 engine. Someone told me that the inline 6 doesn't create enough vacuum to make the brakes work properly. They suggested running a hydraulic assist.
Has anyone had experience with this? I used the search, but didn't come up with this particular issue.
Thanks for your help,
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
I've driven and worked on many inline powered vehicles with vacuum boosted brakes, they all worked fine for me.
Bill Burmeister
Riding in the Passing Lane
Those 292 's will hold more vacuum then a V-8. I serviced many of them with vacuum brakes & they work fine.
1972 Chevy c10 Cheyenne Super
H Online: Content
If you want a little safety margin, find a 30 lb. Freon drum and mount it somewhere out of sight, under the bed, etc. and run a 1/2" diameter vacuum line to it through a 1-way check valve. I just use a regular brake booster check valve and grommet, fitted into the blowout safety cut in the tank with a Dremel tool. A little strap steel to mount it, and you've got a vacuum reserve tank big enough for 2 or 3 brake applications even with a dead engine.
Thanks for the quick replies! You guys are awesome! Great advice, Jerry. . .I'll have to do some more learning, but that's the fun of it anyway.
I'm hoping to get the steering hooked up this weekend, but the power steering pump is different with hydro boost on the brakes. Now I can proceed with the stuff I already have without going to the junk yard again.
Craig
CK
Used to drive 1967 Chevy 48 passenger school buses with the 292 and vacuum booster brakes, never had any problems. Should do fine.
