3 members (J Lucas, HandyAndy, TUTS 59), 39 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#642021 04/30/2010 1:51 AM
I put a chevy 350 in my 58 apache. I purchased some hugger headers because I couldn't get anything else to fit. When I put the headers on, I had to hammer in the header a little bit so that it wouldn't hit the steering box.
Has anyone had any problems overheating their steering box? Should I put a reflective insulation around the steering box? Any advice on this would be appreciated.
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
That would seem to be a good idea. My concern would be cooking the seal and causing a leak since they are not made to get as hot as a header would probably bake at. If you have a digital electronic thermometer take a reading and see what your up against.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thank you. I was thinking the same thing but didn't want to spend $15-20 if I didn't have to.
---Casey---
---Casey---
