A while back a friend dropped my engine when I had it out. It's a 235 from a 57 chevrolet. This in turn broke my harmonic balancer even though it barely fell. When I found another one, I learned that there were apparently two different sizes. I believe, though I could be wrong, that this size difference took place somewhere in 1955. One size had the pulley at 6 inches, the other had a larger pulley at 6 1/2 inches.
Now, the correct 6 1/2 inch pulley I found and replaced has become loose and I need to find another one.
Hopefully, this might help so no one else winds up buying the wrong pulley. Also, I'm trying to find a good used 6 1/2 pulley if anyone has an extra.
Brandon
The Correct Size for a '57 235
Picture of correct Size The incorrect size for a '57 235
Incorrect Size for a 235
