7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel),
94
Mod | | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 29 | Hi Guys -
I searched the old topics and did not see an answer to this.
I have justed overhauled a military GMC 302 out of an M211 to go into my '54 GMC 350 dump/flatbed. The old engine was a 270. The old civilian bellhousing bolted on fine, but the 270 starter bumps into a small hummock on the 302 block that is not present on the 270. I read somewhere that this hummock can be ground down to allow the civilian starter to fit, but wanted someone smarter than me to comment before I grind a hole in the block of my new engine.
Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, the hump must be ground. There is a very good discussion on the Old GMC site about that and other changes that need to be made. You'll have to register then go to the discussion forums and do a search. | | |
