4 members (Peggy M, Gray_Ghost, Wally / Montana, 2-Ton), 106 guests, and 2 robots.
Topics128,052
Posts1,055,717
#641603 04/28/2010 6:55 PM
Hi Guys -
I searched the old topics and did not see an answer to this.
I have justed overhauled a military GMC 302 out of an M211 to go into my '54 GMC 350 dump/flatbed. The old engine was a 270. The old civilian bellhousing bolted on fine, but the 270 starter bumps into a small hummock on the 302 block that is not present on the 270. I read somewhere that this hummock can be ground down to allow the civilian starter to fit, but wanted someone smarter than me to comment before I grind a hole in the block of my new engine.
Ranger #641700 04/29/2010 3:05 AM
Yes, the hump must be ground. There is a very good discussion on the Old GMC site about that and other changes that need to be made. You'll have to register then go to the discussion forums and do a search.
