3 members (DaveV, Phak1, TUTS 59),
223
Mod | | | Forums66 Topics128,162 Posts1,056,942 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64149 08/09/2006 6:44 PM | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | i scored a orig. fram oil filter, question is where do i attach the 2 lines to the 216 block? | | |
#64150 08/09/2006 7:43 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put a tee in the outlet to the oil pressure gauge & run a hose to the side of the filter. There is a plug down on the edge of the block near the oil pan in frnt of the exhaust pipe. Remove this plug & run the hose from the bottom of the filter to this drain hole. Be shure the hoses are good. Many engines have been ruined by these hoses breaking & loosing all the oil. Most specialty parts places have complete hose & fitting kits. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#64151 08/09/2006 8:17 PM | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | dbone, here is a pic of a fram on a 216. | | |
#64152 08/10/2006 12:35 AM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Excellent picture. If you have an earlier 216 with the oil distribution valve you will "T" at the top of the valve where the rocker oil line connects.
#64153 08/10/2006 1:06 AM | Joined: Jul 2006 Posts: 22 New Guy | | New Guy Joined: Jul 2006 Posts: 22 | I added a 3/16-inch ss line from the filter to the left side of mt 235 engine. I put in two clamps for rigidity. I also wrapped wire around the line where ever there is a bend to keep the line from kinking. See pics 31,32, and 33 on www.picturetrail.com/cjb40
Pizza40
