4 members (59 fleet, Wally / Montana, David Bush, Paul_WNC), 93 guests, and 2 robots.
Topics128,051
Posts1,055,734
#640432 04/24/2010 12:44 PM
why drill the thermostat and what size hole?
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
1/8 inch and it's so as You're filling the rad and engine with water the air comes out of the top of the engine and there is no trapped air in the engine when You warm it up the frist time.
Pete
In addition to what Pete said, there's the ongoing advantage of having the thermostat exposed to a small amount of circulating water as the engine warms up rather than heating stagnant water under the thermostat by convection only. On my 235, I had a problem of the temp. guage swinging almost into the red zone before the thermostat would open, after I drilled the 1/8" hole in the flange, as soon as the engine reaches operating temperature, it stays right there.
thank's for the info, it's may help.
Mr.Giant
I never drill thermostats unless the OE was drilled. Never had a problem with air pockets or overheating.
Bill Burmeister
You are lucky.
I used to only drill replacement thermostats for my 261s (because the original thermostats were drilled). However, I now drill all thermostats that I put in a 216/235/261 engine. Why not (it won't hurt anything, it allows a little low-temp circulation, and it might help clearing air from the system)?
1 Offline
I have never drilled a stat myself. I figured if getting airbound was a hugh deal the stat manufacturers would drill it when they build it. Not saying its a bad idea but I have personally never had a issue with any older (pre 1990) engines getting airbound. I have on the otherhand gotten plenty of junk cheap stats out of the box. I started using Stant Superstats exclusively and never had a issue. I have noticed some rice burner stats have a hole with a checkball staked into it and I assume its probably a air bleed of some sort.
Ex Hall Monitor
Ex Hall Monitor
My original thermostat stuck open last summer and I replaced it with a modern one. I didn't drill it and so far no problems.
Originally Posted by 1959fleetoption
. . . I figured if getting airbound was a hugh deal the stat manufacturers would drill it when they build it. . . .
When I bought my first 261 in 1971 (a 1960 engine out of a large school bus), the thermostat had a hole in it and the replacement thermostat (from NAPA) also had a hole in it. The 261 thermostat and housing (and water pump) was significantly different from those items on a 235.
What's the advantage?
panic #640995 04/26/2010 4:44 PM
panic; Keep reading, the advantage is explained in the rest of that post, at least in my demented mind. During warmup (thermo. closed) there can be uneven temps in the head (for example where the temp guage sender is). The thermostat is heated only be convection as no water is yet circulating possibly leading to a faulty reading by the thermostat. With the 1/8" hole, a small amount of water will circulate, evening out any hot spots and bringing the head temperature to a more even heating that the thermostat can react to. In addition, if the old girl needs a good burp, she doesn't have to wait until the thermo opens.
Also, I'm thinkin' it can't be a good thing to have a 55-year-old cast-iron head a lot hotter at one end than at the other end, even if it's just for a few minutes.
Actually, coolant does circulate even with the thermostat closed. All the liquid-cooled engines I'm aware of have internal passages designed to keep the coolant moving through the water pump, block, and cylinder head even with the thermostat in the closed position. Drilling the thermostat might prevent an air bubble from forming in the immediate area of the stat, but it won't have a significant influence on coolant circulation. Some thermostats have a positive blockoff feature to close off the bypass port once they open, but that's not so on a stovebolt engine.
The coolant/water by-pass from the block to the head (that Jerry refers-to above) is described in the right column of this page from the 1954 Shop Manual.
Thanks guys, that's good info there. I love this site, good place to learn!!
If you want to avoid the belching of trapped air in the system just fill the block with coolant before installing the thermo.
I usually drill a tiny 1/16" or 3/32" hole in a thermostat if it doesn't have one already, many do.
Don't expect it to do anything but help burp the air out, and even if turns out it's not necessary I'm sure it can't hurt.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #641269 04/27/2010 4:41 PM
Don't see the reference to drilling the thermostat - it says that the front of the block is already vented? To where?
panic #641298 04/27/2010 6:18 PM
I use the top heater hose connection to burp the system when I refill it. I find that works for me.
1951 1 Ton Completed
panic #641299 04/27/2010 6:19 PM
The bypass passageway routes part of the coolant flow from the area of the thermostat back to the water pump inlet. It keeps the coolant from forming stagnant spots that would result in steam pockets if it was not in motion. On some engines like the heavy-duty 261's and 292's the bypass passageway is much larger to flow more coolant when the thermostat is closed. Drilling the thermostat valve is not a factory-reccomended procedure but it seems to work to avoid an air pocket forming near the thermostat.
I drill 3 3/16" holes on the T-stats in the boat because the Mercury ones are $20 and a stant is $4 The car has a jiggle pin installed already.
SPL Offline
While you all are talking thermostats what temp stat should I put back in my '57, 235, 1/2 ton PU?
SPL #644031 05/06/2010 4:09 PM
185 was standard with perm AF.
