1 members (NJC),
138
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 33 | Hello all,
I just redid all my gaskets on the tranny (ie: top cover, PTO cover and the 2 circled one on the back) and as I did so I looked in there to see what shape the gears are in. They all look good and there was no metal shavings in the gear oil that might suggest any bad omens.
MY question is this: What might be causing the "rattle" sound that seems to eminate from the stick shift lever? -The rattle is there even when I have my hand on the stick and I notice that it disappears when I go in to 4th gear (then the only sound is the high pitched hummm) ( I also heard these are inherently noisy anyway). I have the 4 speed (granny low) sm420 trans.
Thanks for your help! Shane Hamilton Warrensburg, MO | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Those 4 speeds do rattle some with the rough cut gears. Does it go away with an increase in rpm ? What weight gear oil did you use ? I would use a good 90 weight, like Napa # 75-210 .Let us know how you make out.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | When you're running in 1st., 2nd., or 3rd. gear, power is being transmitted through the input shaft, cluster (counter) gear, reduction gears, and then to the output shaft. In 4th., the power goes straight in and out, and while the countergear is still turning, it's not loaded at all. It's possible the needle bearings that support the countergear on its shaft are worn, or it's more likely that you're just hearing the normal noises of power going from one gear to another. It's going to be VERY noisy in granny gear, because that one has straight-cut teeth. Jerry
