Hey Mark,
My camera died. I attempted to take photos, but need to purchase a new battery. Sorry, perhaps Dave can help with the photos? I did take measurements. From the top of the fender, (1st ) screw measures 1“. Taken from center-point of the lowest screw (#1) to the next screw (#2) is 11-½“. Moving up-towards the center of the hood to screw (#3), center-point to center-point is 8-½“, and then lastly from the 3rd screw to the 4th screw, (adjacent to the aft hood hold down) (#4) is 16-3/8 “. In reading your description, the holes were filled over. If you look under your dash, the holes should still be evident with extra filler protruding? If so, you can always use the original holes and from under the dash, back-drill from inside to outside for a perfect location of the original holes. Sorry again about my camera.
Dale
