2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | guys, i have been seeing a few cars/trucks at my local shows with the cool looking tri-bar headlights, and want to get me a set for my 57. through my search i find there are two different types, steel and plastic housing. steel housings are $50.00 each, http://www.garyscustomlights.com/product_p/gcl700.htmand the plastic housings are $35.00 each http://www.thehoffmangroup.com/autoloc/details.lasso?itemid=HL2would probably lean toward the stell housing ones, but would like to see if any of you have any experience with these lights ? thanks much. leonard | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks larry, i seen those covers, but the ones i am looking at are made into the headlight, behind the glass, right ? thanks.
also, i notice the ones i am looking at are halogen. is there any special modifications i need to do to my wiring or anything else, to run the halogen bulbs ?
thanks guys. leonard | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Without knowing what the wattage difference is between the incandescent(?) you are replacing and the Halogens, it's hard to say. I think it's safe to say that the Halogens will draw more current, how much I didn't find in my quick search. There are other factors to be considered wire gage, and lenght of wire. Here is an article from Hiperformance Chevy; http://www.chevyhiperformance.com/howto/4417/index.htmlThe article has some good thinking behind it. There have also been some posts on using Bosch relays here. I'd do a search for them. IF you are also going to be adding some fog lights or driving lights it would be good to learn how to use the relays. It might also be a good time to check what your total current draw is, and if you might be exceeding the amperage on your alternator. I found this listing in my search, the numbers look a little high but,,,, - Typical current draw; http://townsendsautomotive.com/shared/content/Library/encyclopedia/ch11/11fig16.htmlWhen I was rallying some of the competitors had enough candle power that with all the lights on they were slowly draining the battery, and that was with a 95 amp alternator. Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks for the detailed info larry. just read the super chevy article. seems like yes, i would probably need some relays to power the halogen lights. im not gonna run any fog lights, just the new tri-bar halogen head lights.
im gonna do more research myself, and thanks again for your time.
leonard | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Here's mine. I have style with the plastic housing, they came with an H4 halogen bulb, but I upgraded to Sylvania Silver Star bulbs. It was essentially a plug and play operation. I did not add any extra relays, they run on the regular harness. Haven't had any problems with them at all, the wiring doesn't even get warm.
Bill Burmeister | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I run halogen sealed beams in my '56 with no relays. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks cletis and bill, i guess i wont worry about any relays. that helps a lot. hope to order some in a few weeks. did you guys notice a huge difference in the power of the halogen light at night, over the seal beamed original light ? thanks again.
leonard | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Mine are just standard seal-beams with internal tri-bar & blue dot. Found them at a local rod-shop. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Halogen head lights actually draw less current than incandescent headlights. That is why we began retrofitting our trucks about 25 years ago. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes there is a noticeable difference. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | | | | | | Joined: Mar 2009 Posts: 15 New Guy | | New Guy Joined: Mar 2009 Posts: 15 | I used the same seller & lights when I up- graded the lighting on my '73 Camaro. I also added some relays to my lighting cicuit jus cuz I already them. I also plan on doing this to my truck when the time comes- excellent and cheap up-grade. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | ordered them today. should have them in one week. when i get them installed, i will post pics.
leonard | | | | | Joined: Mar 2009 Posts: 15 New Guy | | New Guy Joined: Mar 2009 Posts: 15 | ordered them today. should have them in one week. when i get them installed, i will post pics.
leonard Cool...I haven't had a chance to look at my '55 light buckets yet, but I had to cut away some material when I installed them on my Camaro. The backside of the light assembly is close to 3" in dia. and I had to hog out my stock ones to make things fit. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | ordered them today. should have them in one week. when i get them installed, i will post pics.
leonard Cool...I haven't had a chance to look at my '55 light buckets yet, but I had to cut away some material when I installed them on my Camaro. The backside of the light assembly is close to 3" in dia. and I had to hog out my stock ones to make things fit. please... no more modifications. LOL. i hope they are a direct bolt in. i will let you all know. leonard | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Mine went in with no alterations.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | Mine went in with no alterations. thats good to know.. thanks bill. leonard | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Do these lights work on both 6 and 12 VDC systems? our truck still has the 6 volt system. Thanks for the help.
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | not really sure if they will work on a 6 volt system.
leonard | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | They would work if you could find a 6 volt equivalent to the H4 bulb fitment.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | got the tri-bar's in today, have them installed. still have to wait for the weekend to aim them and take pics. plugged right in to factory wiring. had to trim the circle opening on the bucket that goes on the back of the headlight. also had to modify that same bucket on the passengers side where the 3 notch openings are, to get the headlight timed correctly where it say "top". cut 3 notches where i needed them. overall an easy install. will post pics this weekend.
leonard | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Lookin' good as always Leonard.  It's great when all the hard (unseen) work is done and you can spend your spare $$$$'s on the shiny/stylish stuff!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2010 Posts: 10 New Guy | | New Guy Joined: Oct 2010 Posts: 10 | I like the decal on the dash! We use to use that image at VMFP-3 1979 - 1981 Hydshp
