4 members (JW51, 51sub, Stovebolt48, carbking), 53 guests, and 2 robots.
Topics128,041
Posts1,055,593
#635933 04/08/2010 9:47 AM
guys,
i have been seeing a few cars/trucks at my local shows with the cool looking tri-bar headlights, and want to get me a set for my 57.
through my search i find there are two different types, steel and plastic housing.
steel housings are $50.00 each, http://www.garyscustomlights.com/product_p/gcl700.htm
and the plastic housings are $35.00 each
http://www.thehoffmangroup.com/autoloc/details.lasso?itemid=HL2
would probably lean toward the stell housing ones, but would like to see if any of you have any experience with these lights ?
thanks much.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
That design was originally(?) done by British Lucas many, many, years ago. These appear to be a repop covers that look close only $30;
http://cgi.ebay.com/ebaymotors/Bull...torsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Larry
I don't own a vehicle that isn't old enough to drink.
thanks larry, i seen those covers, but the ones i am looking at are made into the headlight, behind the glass, right ?
thanks.
also, i notice the ones i am looking at are halogen. is there any special modifications i need to do to my wiring or anything else, to run the halogen bulbs ?
thanks guys.
leonard
Without knowing what the wattage difference is between the incandescent(?) you are replacing and the Halogens, it's hard to say. I think it's safe to say that the Halogens will draw more current, how much I didn't find in my quick search. There are other factors to be considered wire gage, and lenght of wire. Here is an article from Hiperformance Chevy;
http://www.chevyhiperformance.com/howto/4417/index.html
The article has some good thinking behind it. There have also been some posts on using Bosch relays here. I'd do a search for them. IF you are also going to be adding some fog lights or driving lights it would be good to learn how to use the relays. It might also be a good time to check what your total current draw is, and if you might be exceeding the amperage on your alternator. I found this listing in my search, the numbers look a little high but,,,, - Typical current draw;
http://townsendsautomotive.com/shared/content/Library/encyclopedia/ch11/11fig16.html
When I was rallying some of the competitors had enough candle power that with all the lights on they were slowly draining the battery, and that was with a 95 amp alternator.
Larry
thanks for the detailed info larry. just read the super chevy article. seems like yes, i would probably need some relays to power the halogen lights. im not gonna run any fog lights, just the new tri-bar halogen head lights.
im gonna do more research myself, and thanks again for your time.
leonard
Here's mine. I have style with the plastic housing, they came with an H4 halogen bulb, but I upgraded to Sylvania Silver Star bulbs. It was essentially a plug and play operation. I did not add any extra relays, they run on the regular harness. Haven't had any problems with them at all, the wiring doesn't even get warm.
Bill Burmeister
I run halogen sealed beams in my '56 with no relays.
thanks cletis and bill, i guess i wont worry about any relays. that helps a lot. hope to order some in a few weeks.
did you guys notice a huge difference in the power of the halogen light at night, over the seal beamed original light ?
thanks again.
leonard
Mine are just standard seal-beams with internal tri-bar & blue dot. Found them at a local rod-shop.
1940 Chevy KC 1/2-Ton
Halogen head lights actually draw less current than incandescent headlights. That is why we began retrofitting our trucks about 25 years ago.
Yes there is a noticeable difference.
Cletis #636659 04/11/2010 12:11 PM
cool.
tomorrow i am ordering a set of these for $32.00... cheap enough huh ?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380221760216null&viewitem
leonard
Originally Posted by RATRODKING
cool.
leonard
I used the same seller & lights when I up- graded the lighting on my '73 Camaro.
I also added some relays to my lighting cicuit jus cuz I already them.
I also plan on doing this to my truck when the time comes- excellent and cheap up-grade.
ordered them today. should have them in one week. when i get them installed, i will post pics.
leonard
leonard
Cool...I haven't had a chance to look at my '55 light buckets yet, but I had to cut away some material when I installed them on my Camaro.
The backside of the light assembly is close to 3" in dia. and I had to hog out my stock ones to make things fit.
leonard
please... no more modifications. LOL. i hope they are a direct bolt in. i will let you all know.
leonard
Mine went in with no alterations.
Bill Burmeister
thats good to know.. thanks bill.
leonard
Do these lights work on both 6 and 12 VDC systems? our truck still has the 6 volt system. Thanks for the help.
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
A49ER #638055 04/16/2010 12:31 AM
not really sure if they will work on a 6 volt system.
leonard
They would work if you could find a 6 volt equivalent to the H4 bulb fitment.
Bill Burmeister
got the tri-bar's in today, have them installed. still have to wait for the weekend to aim them and take pics.
plugged right in to factory wiring. had to trim the circle opening on the bucket that goes on the back of the headlight. also had to modify that same bucket on the passengers side where the 3 notch openings are, to get the headlight timed correctly where it say "top". cut 3 notches where i needed them.
overall an easy install.
will post pics this weekend.
leonard
Lookin' good as always Leonard. thumbs_up
It's great when all the hard (unseen) work is done and you can spend your spare $$$$'s on the shiny/stylish stuff!
More pix on Flickr.
I like the decal on the dash! We use to use that image at VMFP-3 1979 - 1981 Hydshp
