5 members (3B, Otto Skorzeny, 55shaker, rick46ia, 57 Drifter), 73 guests, and 1 robot.
Topics128,023
Posts1,055,365
Members48,420
#64068 08/08/2006 9:24 PM
The opening circled in red.
http://i45.photobucket.com/albums/f91/serb28/Carmen%20Jones/Carb.jpg
I am curious since I don't see it on other 235 engines. The PO has a hose running from the oil bath air cleaner to this "opening." Any help is appreciated.
Thanks, Steve (formerly Clifford 3600 until the last system "crash")
Today is the best day of my life!!!
#64069 08/08/2006 9:33 PM
I'm gonna take a guess and say that it's some sort of PCV system. It looks similar to the hookup for the forward control models.
Bill Burmeister
#64070 08/08/2006 9:37 PM
2 Offline
I agree. Aren't those usually on top of the valve cover though?
1967 Chevy truck "The Hurricane"
WARNING:
This suspect has a tendency to jerry-rig.
"My engine ain't fast, but I pulled a tree trunk out of the ground once."
#64071 08/08/2006 9:45 PM
On the forward control models the hookup was a t the rear of the cover, as the air filter was mounted at the right rear of the engine.
Bill Burmeister
#64072 08/09/2006 4:07 AM
Thanks for the help... I am upgrading to a 2 bbl carb and will not have an oil bath air cleaner. Do I need that hole and if not, how do I cover/seal it up?
Also, (exscuse my ignorance) what is a forward control model?
#64073 08/11/2006 2:25 AM
This is a modification that could be made for positive crankcase ventalation.I would sugest that you keep it in the sinse that gasses are sucked from here and are run thru the engin and out the exhaust.I wished I had found that v cover as I had to make the mod to my engine so the breather tube gases didn't come into the cab.Sell that cover and get one with out that outlet.
#64074 08/11/2006 10:21 PM
Do I need to replace the valve cover or can I just fashion some kind of "seal" to plug up the hole?
Any other thoughts or suggestions?
#64075 08/11/2006 10:40 PM
Well yo can just weld a plate over the top of the hole, but I would use the hole for a pcv valve and eliminate those crankcase fumes from entering the cab.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#64076 08/11/2006 10:44 PM
Wait a min. you are from PA and Tx. ? Texas is big but it dont border Pa. So what gives.
Transplanted Texan of wantabe Texan? I realy can't blame you for being a wantabe.
#64077 08/11/2006 11:07 PM
My wife is from the Texas panhandle. Our primary home is currently in PA, but we also have a small house in TX to use when we visit her family, go on vacations, etc... So yes, I am from PA and TX. Some day in the future, we be perm rfesidents of TX. I think I was a Texan in a previos life!
As for the pcv valve, how would I install one? I have the hole in the valve cover, and am replacing the oil bath cleaner when I upgrade to to a 2bbl carb.
#64078 08/12/2006 9:39 AM
I have a 1952 forward control model. With a 235 And I do not have this??
Thanks Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
#64079 08/12/2006 4:12 PM
Maxx,
Would you mind describing to me what a forward control model is? I am still new at this! Thanks...
#64080 08/12/2006 8:12 PM
My 1952 GMC Grumman Olson Kurb Side (Comet)
3/4 ton forward control chassis.235 inline six cylinder single barrel updraft carb 8 ft. 1080lb. Alloy Body with 300cu.ft. Load space on 104" wheelbase 1 1/4 ton payload capacity on PM 152-22 Chassis.
The Chevy model# is 3700 or 3742 a Commercial ¾ Ton.
3800 is the 1 Ton (Double Duty)
Forward Control Delivery Chassis
It is a step van, short wheel base, with an aluminum body.
This is a link to one or two on ebay
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ih=005&item=150016398310&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&rd=1&item=270004265846&ssPageName=STRK:MEWA:IT&ih=017
and this one is Tom & Kathy's stovbolter
http://www.stovebolt.com/gallery/truhlar_tom_1953.htm
hope this helps
Maxx
#64081 08/13/2006 4:51 AM
The easy way is to use a piece of hose that fits the spigot on the valve cover,long enough to plug a pcv into,and another piece on the other end of your pcv long enough to reach your air filter base. If your air filter doesn't have a spigot to plug the hose onto,the parts stores have kits to do this. They're over with the chrome air filters. Usually about 4 or 5 bucks.Be sure the pcv you choose is installed so air will go through it into the air filter but not into the valve cover. (the pcv may have a different hose size going in than going out.) Should be an easy install.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#64082 08/16/2006 1:12 PM
Thanks for all the help/input. From what I am hearing, this is probably not the original engine since I do not have a forward control truck.
I will be in Texas for 3 weeks starting next week so I will be upgrading to a 2bbl carb and adding the pcv then. I'll keep you posted.
Thanks again!
#64083 08/17/2006 1:32 AM
Good info here in the 1947-1954 truck factory assemble manual,section 6 sheet 13.00,5.02.The one I used on the modification for my 53,3100 was modled after the one on Sect.0 sheet 4.00. Workes great.Aso a great talking item at the showes.Good luck.
