| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Hey all I was servicing the driveshaft yesterday and I thought the middle carrier was a bearing, Then I found it is a rubber "boot" that supports the end of the enclosed shaft and it looks like it acts as a seal. Does anyone have experience rebuilding these? Jim Carter's has a 3/4 ton drive shaft carrier bearing rubber cushion, is this the correct piece? Thanks, Sam | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think the parts in Carter's catalog are probably what you are looking for. However, they are improperly named. The carrier bearings are inside the rear end. The center bearing and cushion is what supports the drive shaft in the center. I would call them and make sure. However it is very often that the center bearing is misnamed and it makes ordering parts difficult when you only have part numbers and no picture. | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Thanks for the info. I will probably stop over there to inspect the part to see if it is a match. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Take a look at this album Sam. There are a few scattered pictures of the work that I did on my drive line and the center supprort. Might help you with yours. http://www.pbase.com/dennygraham/driveline&page=all Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Great pics- Where did you get your Center support rubber- looks like a chevs of the 40's label? | | | | | Joined: Jun 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 47 | Hi -
I will be installing a New Process A-833 4-speed overdrive transmission in my '49 Chevy 3600 pick-up. Do you think I should modify my existing two-piece drive shaft or go with a more modern style two-piece driveshaft?
Thanks! Dan M. | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | I would probably go with a new driveshaft, but I am not an expert. My truck has a half enclosed-half open shaft. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not sure what label you're talking about Sam? I don't remember where I bought the support. One of the "Big four", Chevy Duty, Chevs of the 40's, JC, or The Filling Station. DG
| | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | in one of your pics the rubber is still in the bag with a printed label on it. I will check out the filling station, I have checked the others. Thanks Denny | | |
