2 members (rock331, sron48), 85 guests, and 3 robots.
Topics128,129
Posts1,056,695
Members48,452
While i was rebuilding my head i had to extract a stripped valve cover bolt that the previous owner just left in there. While i was extracting it i somehow drilled into the water/anti freeze port. I am worried that the pressure of the water flow when the engine is running will cause it to leak onto the top of the head and thus circulate through the eninge. any ideas?
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
i sure woudn't put a bunch of money in that head before i found a new one.
i all ready have to buy new valves at 70.00 dollars, a rebuilt head i can get for about 280.00 dollars.
1 Offline
If you already have to have valves installed. They will have to be ground/lapped to fit your seats in the head. You probabaly have a loose valve guide or two in the mix. If you add up the required machine work to do it right, you may already be at the 280.00 dollar cost of the reman. I would drop your old head off at a local machine shop and get a estimate on repair and weigh the cost between the two.
what is the valve guide
Drill and tap the offending hole for a 3/8" bolt and plug the hole with a short 3/8" bolt installed with LocTite. Cut it off flush with the top of the head. Then center-drill the cutoff bolt and tap it for the correct 1/4"X20 valve cover bolt. Just don't drill all the way through the 3/8" plug with the tap drill. Problem solved!
do these inliners have valve guides, because i sure dont have any on this head.
The valve guide is a bronze cylinder the valves run up and down in.
Another fix for the drilled thru hole depending on how much material is there would be to put a set screw in the bottom. Measure the length of the hole, You need enough length so the valve cover screw won't bottom against the set screw. The set screw should still have 1/4-5/16 of it's thread in the material. Then use some thread sealer on the set screw and run it down. This is essentially what you are going to have to do with the head bolts as they also go into the water jacket.
Larry
I don't own a vehicle that isn't old enough to drink.
how can you tell if the valve guides are bad, i am looking in the valve "guide" on the head and its just the hole for the valve to go up and down. there does not appear to be a sleve installed in side the hole.
The valve guides in the Chevy head are cast in place, simply part of the cast iron of the head. Machine shops center up in the old guides, drill and ream them out, and install pressed-in replacements. If the head of the valve has a visible amount of wobble when it's pushed from side to side with the valve spring removed, the guide either needs to be sleeved with a thin bronze insert, or replaced. I used to do a lot of the ream & sleeve repairs, but recently, it's become more popular to replace the entire guide to repair a worn one.
i do not have any play in the valves when i put them in the head, they seem to be very tight
Riding in the Passing Lane
That hole you drilled through, you could put a stud in it & seal it with locktight.
1972 Chevy c10 Cheyenne Super
P.M. sent to ya smile
1951 restoration on website
http://www.hanklong.com
are you going to take the head to a machine shop? they can check the valve guides for a very small cost. they can loosen up a little if the head is cleaned too, but if they don't have much wiggle that's good. someone experienced (not me) can tell by feel if they need replaced usually. good luck.
thanks, i think i am going to put it back together with new valves and be done with it. I rechecked the valves this morning and there is very little play if any, depending on your definition of play.
Be sure the guides are clean. A surprising amount of varnish can accumulate in a guide, hiding looseness. I use a bronze rifle brush, carburetor cleaner, and a variable-speed drill motor, if the proper guide cleaning tools are not available.
ok, i have the rifle brush and card cleaner i will start it now.
1 Offline
Not trying to be rude but I dont want to see you waste your money and time. If you do not have the new valves ground and matched to the seat then they will leak and burn up in a short time. Thats if they even seal at all. The seal between the valve and seat is a precision metal to metal seal with the sealing surface being a certain width so as the valve stays cool. You cannot take a valve out of the box, slap it in the head and expect a seal. Theres just a lot more to it then that.
no kidding buddy, thats why i plan to lap the new valves to the head. The problem is some of the old valves are to pitted to be machined.
