1 members (J Lucas),
85
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64023 08/08/2006 5:20 AM | Joined: Aug 2006 Posts: 8 Junior Member | | Junior Member Joined: Aug 2006 Posts: 8 | My 49 GMC has the closed drive-line and differential with the stock 4.11:1 gear ratio. Does anyone have experience with converting diff to 3.55:1 with a kit like that available from Patrick's? Is it worth doing since my truck is almost 100% stock? | | |
#64024 08/08/2006 5:34 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | G'day mate,
Fred Stevens has a great write up on this in the Tech Tips section. I put the 3.55 kit in my 41 at the end of last year. I thought long and hard about whether to do that or go to an open driveline. Whether its worth it really depends on how you use the truck. The 41 is a daily driver for me and I do a few longer trips. There is a noticeable drop in revs. With 31 inch tall tyres the truck would cruise happily at 50mph. Now it cruises really well at 60 - 65 although I usually sit at just under 60. If you do decide to put in the 3.55 get the overhaul kit as well and replace all the bearings etc. If you have any more questions, fire away. Welcome to the bolt.
Bob | | |
#64025 08/08/2006 10:39 AM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | I did the Patrick's upgrade BECAUSE my truck is almost 100% stock AND I wanted a daily driver. We've put about 850 miles on it since changing to the 3.55:1 gears and life is good.
Like mozzie says, if you go this route, get the overhaul kit along with the ring and pinion kit. | | |
#64026 08/08/2006 10:54 PM | Joined: Aug 2006 Posts: 8 Junior Member | | Junior Member Joined: Aug 2006 Posts: 8 | Thank you both. Did either of you do the work yourself? | | |
#64027 08/09/2006 12:39 AM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Yup, wasn't too bad a job, just make sure you can lay your hands on the special tools, dial indicator, pin spanners, etc. | | |
#64028 08/09/2006 1:02 AM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I talked to the guy that did my engine rebuild this past week. We got to talking about this job and he can and has done it for $3-400. Does this sound reasonable? | | |
#64029 08/09/2006 11:58 AM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | I think that $300 - $400 is VERY reasonable for the job involved. Bear in mind that $60 - $75 per hour seems to be a going rate for mechanical work on autos, trucks, motorcycles, etc.
I had maybe 20 hours of my time involved, but a lot of that time was spent cleaning parts, reading manuals, searching for or making tools and so forth. | | |
#64030 08/09/2006 2:09 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I think its a job you could do yourself. It is a messy one, but you can do it yourself. It just means you'll need to buy a few tools.
I was at harbor freight yesterday and noticed they have pin spanners ($5) dial indicators and magnetic bases (about $20 for the set), feeler guages and most of the other tools you need to rebuild these rear ends.
Speedway motors also has a rear end rebuild tool kit.
As far as the install kit goes- It is definately a good idea to replace the bearings etc... I would check with some of the standard parts houses, especially NAPA, to see if the price they can sell you the individual parts compares to Patrick's. Having a list of the parts you need is very helpful. In the more modern 10/12 bolts there are two axel seals, a housing seal, a cover gasket, three bearings, a crush sleeve and a shim kit. Maybe someone can chime in with the parts for this project...
#64031 08/11/2006 4:03 PM | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Randy's Ring and Pinion is also an excellent source - check with them for any specialized tools required. Good Luck!
'67 Chevy 1/2 Ton 283 350 Auto. | | |
