1 members (1 invisible), 92 guests, and 2 robots.
Topics128,109
Posts1,056,572
Members48,448
#639636 04/21/2010 4:30 PM
Have any of you guys used the brake caliper kit from POR -15. Its about $40 and comes with the regular black paint, a top coat with color of you choice and all the prep stuff. My questions are:
Did you remove the caliper or paint it on then vehicle?
How did it turn out?
I haven't used POR15 for that purpose but I have used enamel paint which has worked out fine.
How well the paint last is, in my opinion, related to a couple of variable factors.
The factors are heat, water and salt exposure.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Worked great....follow their instructions and it will do fine. Removed the caliper when I used it. Heard several b@%ch about POR on the boards. Most tried to do it their way, skip a step, etc. So their results were less than perfect.
Hank
1951 restoration on website
http://www.hanklong.com
