0 members (),
83
0
Mod | | | Forums66 Topics128,108 Posts1,056,566 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Have any of you guys used the brake caliper kit from POR -15. Its about $40 and comes with the regular black paint, a top coat with color of you choice and all the prep stuff. My questions are:
Did you remove the caliper or paint it on then vehicle?
How did it turn out? | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I haven't used POR15 for that purpose but I have used enamel paint which has worked out fine. How well the paint last is, in my opinion, related to a couple of variable factors. The factors are heat, water and salt exposure. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Worked great....follow their instructions and it will do fine. Removed the caliper when I used it. Heard several b@%ch about POR on the boards. Most tried to do it their way, skip a step, etc. So their results were less than perfect.
Hank | | |
