6 members (Gdads51, Otto Skorzeny, TUTS 59, amtrakjoe, fonz8261, mk72), 78 guests, and 3 robots.
Topics128,043
Posts1,055,524
Members48,424
#640033 04/22/2010 10:43 PM
Wife wants an automatic. A 235 with powerglide is available near me. It is from a 54 Belair. Will this fit in my truck? If it has lower rear gears than mine, Can the whole drivetrain swap? She would love the auto and I would like lower gears. Is this possible?
lightflyer1 #640094 04/23/2010 2:21 AM
It can be made to work, but it'll be much more work that what you'll get out if it. The 'Glide only has 2 speeds, and the rearend is not interchangable with the truck. It will also be a higher gear, most likely a 3.55, than the 4.10 that your truck has. I'm not 100% sure if the 'Glide will directly bolt up to the torque tube in the truck.
A better route might be to look at the adapter plate from Langdons and use a 700R4, which will get you not only an automatic, but also an overdrive gear. You'll have to go to an open driveling, but that's not really all that difficult. If you search the site, that conversion ha been covered extensively.
Bill Burmeister
LONGBOX55 #640137 04/23/2010 4:00 AM
A better search has educated me. Thanks!
