3 members (Peggy M, RLB, TUTS 59), 105 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
Junior Member
Junior Member
I have a sbc truck bellhousing(3815891) any would like to know what year truck it came out of. I've searched the web and couldn't come up with anything.
Riding in the Passing Lane
A photo would help. If it is cast iron & open at the bottom it is 55-72 1/2-1 ton. If it is larger than the normal bolt patern & has a bolt hole on top it is a large truck houseing & uses an adapter plate. If it aluminum it is 73 up.
1972 Chevy c10 Cheyenne Super
Junior Member
Junior Member
Its cast iron and open on the bottom and I plan on using it on my sbc(350)swap in my 59 3600. By any chance would you know what clutch setup I would need for the conversion. The original setup on my 6 cyl is a diaphram pressure plate with a 11 inch disc. I plan on using an 11 inch setup with the sbc to match the flywheel I purchased with the cast iron bellhousing.
That number shows it to be a 63-66 truck bellhousing for a V8. It should take a 10.5" to 11" clutch.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Junior Member
Junior Member
thanks for the help
Got your e-mail. Yes I have done 2 of those & use the 11 in. clutch. Get a matched set new. It doesn,t pay to use reman clutches anymore.
