| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63992 08/07/2006 6:34 PM | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | I have a sbc truck bellhousing(3815891) any would like to know what year truck it came out of. I've searched the web and couldn't come up with anything.
John | | |
#63993 08/07/2006 9:40 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A photo would help. If it is cast iron & open at the bottom it is 55-72 1/2-1 ton. If it is larger than the normal bolt patern & has a bolt hole on top it is a large truck houseing & uses an adapter plate. If it aluminum it is 73 up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63994 08/08/2006 12:55 AM | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | Its cast iron and open on the bottom and I plan on using it on my sbc(350)swap in my 59 3600. By any chance would you know what clutch setup I would need for the conversion. The original setup on my 6 cyl is a diaphram pressure plate with a 11 inch disc. I plan on using an 11 inch setup with the sbc to match the flywheel I purchased with the cast iron bellhousing.
John | | |
#63995 08/08/2006 1:29 AM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | That number shows it to be a 63-66 truck bellhousing for a V8. It should take a 10.5" to 11" clutch. | | |
#63996 08/08/2006 7:49 AM | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | | | |
#63997 08/08/2006 10:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Got your e-mail. Yes I have done 2 of those & use the 11 in. clutch. Get a matched set new. It doesn,t pay to use reman clutches anymore. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
