2 members (Guitplayer, MickeyP), 70 guests, and 2 robots.
Topics128,021
Posts1,055,356
Members48,420
#639851 04/22/2010 1:04 PM
Does anybody have a 1937 generator that they KNOW is original. I think mine is non original. It was never drilled anywhere for the data plate. If you're sure, I'd sure appreciate it if you could tell me the correct part number. If you could supply a picture I could probably tell if mine is correct. Thanks
Jeff,
the generator on my 38 is not original. Mine should have the "three brush" generator and the regulator should have only two relays. Someone updated mine to the more modern 6v three relay type. I am not going to change it because it is much superior to the third brush type.
1951 1 Ton Completed
