1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | Does anybody have a 1937 generator that they KNOW is original. I think mine is non original. It was never drilled anywhere for the data plate. If you're sure, I'd sure appreciate it if you could tell me the correct part number. If you could supply a picture I could probably tell if mine is correct. Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Jeff, the generator on my 38 is not original. Mine should have the "three brush" generator and the regulator should have only two relays. Someone updated mine to the more modern 6v three relay type. I am not going to change it because it is much superior to the third brush type. | | |
