| | | Forums66 Topics128,192 Posts1,057,226 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 5 New Guy | | New Guy Joined: Apr 2005 Posts: 5 | I have a 51 Chevy 1/2 ton with the 4 speed transmission. Is the 4 speed transmission in the 3/4 ton exactly the same as for the 1/2 ton, or what is the difference, and what is needed to make it work? Then is the u-joint the same? | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | 48-54 is the same. In 55 they started using a parking brake on the back of the transmission, but the transmission itself is the same. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As Ken stated, the transmission is the SM420 for both applications. No the U-joint is not the same. The 3/4 ton U-joint is heavier and is about impossible to find. No one is making a replacement for it and about the only way you will find one is if someone has some NOS on the shelf or a good junker. Joe, if you have a four speed in the 1/2-ton already then why are you asking about the 3/4-ton??? All of the parts to rebuild the SM420 are avalable from Novak and all of the parts for the 1/2-ton U-joint and coupling are avalable from most of the vendors. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 5 New Guy | | New Guy Joined: Apr 2005 Posts: 5 | Know where a 3/4 ton truck is with a good 4 speed transmission and would like to keep a good spare transmission ready to put in my truck. | | |
