3 members (52Carl, klhansen, Bill Hanlon), 334 guests, and 5 robots.
Topics128,159
Posts1,057,037
Members48,460
I have a 51 Chevy 1/2 ton with the 4 speed transmission. Is the 4 speed transmission in the 3/4 ton exactly the same as for the 1/2 ton, or what is the difference, and what is needed to make it work? Then is the u-joint the same?
48-54 is the same. In 55 they started using a parking brake on the back of the transmission, but the transmission itself is the same.
As Ken stated, the transmission is the SM420 for both applications. No the U-joint is not the same. The 3/4 ton U-joint is heavier and is about impossible to find. No one is making a replacement for it and about the only way you will find one is if someone has some NOS on the shelf or a good junker.
Joe, if you have a four speed in the 1/2-ton already then why are you asking about the 3/4-ton??? All of the parts to rebuild the SM420 are avalable from Novak and all of the parts for the 1/2-ton U-joint and coupling are avalable from most of the vendors.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Know where a 3/4 ton truck is with a good 4 speed transmission and would like to keep a good spare transmission ready to put in my truck.
