| | | Forums66 Topics128,050 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Starting my 216 cid is no problem. Fires up every time on the first try. Problem is that I MUST pull the choke out 1/3 of the way in order for it to run smoothly. If I do not then it coughs and sputters, especially when shifting into 2nd gear or when under a load, like pulling up hill around a curve in 3rd gear. This continues until it gets really hot, about 15 minutes, then I can push the choke in and it usually does not do it too much more. It actually sounds like it's back firing through the carb when it happens. I know it is running rich because the oil smells like gasoline after some miles are put on the new oil change. The engine runs beautifully in every other way.
Is there an adjustment I can make on the carb or distributor or do I need to buy and install a carb rebuild kit? I'm no mechanic but I'm handy with a wrench.
Thanks, Spot
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have to pull out the choke to get it to run good it is usually a sign of a lean mixture. First I would try advanceing the timing a little. Set the idle mixture a little on the rich side. If that doesn't do it you will need to go into the carb. If it is a Rochchester it is easy to pull the top off & check it out. Check the float level. Make sure the power valve plunger goes up & down & pushes the ball off the seat. If it's a Carter you will have to pull it & rebuild it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 41 Apprentice | | Apprentice Joined: Mar 2010 Posts: 41 | i had bad gas give me symptoms like this.I would check points,timming and all the simple stuff before digging to deep
55 stepside 3600 67 chevelle ss conv joe springfield,PA
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | the oil smells like gasoline
Leaking needle & seat Leaking fuel pump | | |
