2 members (Hotrod Lincoln, Millenimech), 76 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
I know I took this part off somewhere around the bellhousing but I'll be darned if I can figure out where it goes. Can you help me?
[img]http://memimage.cardomain.net/member_images/3/web/2235000-2235999/2235628_16_full.jpg[/img]
[img]http://memimage.cardomain.net/member_images/3/web/2235000-2235999/2235628_14_full.jpg[/img]
Thanks.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
hello jerry. it looks like a spring that goes on the foot pedal starter assembly.[cross shaft drivers side bracket].
our garage is a non-profit organization
Looks like a mouth bit for a horse. grin
Thanks Gary; I'll check that out. Cute Rattletrap.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
Hey Jerry, I confirmed it. It's the spring for the left side of the cross shaft. Checked both the assembly manual and the '55.
Bill Burmeister
Great. I'm heading to the manual now. I was so sure it was a clutch piece that I didn't look anywhere else. Thanks.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
Ok; the 57 assembly manual doesn't show this piece very well. Anyone have a link to a 55 or 56 manual that may have a blow-up of this spring? Maybe someone could scan the right page and send it to me? Please!
Perhaps an explanation of the purpose of this piece and the orientation of the small loop in the middle. Thanks for you help.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
55 2nd shop manual - but doubt you'll see a better pic there - the assembly manual is the same 55-59, and it doesn't show much except it's location ... sect6 sheet6.00, called "597417, spring" - goes on the shaft on each side of the mounting bracket w/ the center loop underneath out of sight
