2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
#638127 04/16/2010 4:48 AM
what year body parts will work with the 36. the 34-35 high cab grill ,fenders look the same . im trying to spread my search . the 37 hood looks the same. has any one used these different years on a 36 . thanks
Are you talking about a "high cab" 36, or a "low cab" 36? Some 34-35 "high cab" parts will interchange with a 36 "high cab". The " low cab" 36 shares some parts of the cab with the 37-38. Most cab parts can interchange except the windshield and interior door panels. The rest of the truck will not interchange with the 37-38. The 36 "low cab" has some wood in it, the 37-38 have no wood. The 34-35 "high cab" trucks have a good amount of wood in them.
If I recall correctly you have a lowcab. From what I've seen 34-35 fenders and grill will work. As far as the cab goes the post above is accurate. I'm using a 37 cab on mine.
KC in NH #638418 04/17/2010 4:45 AM
yes i have a low cab .. and was wondering if the grill and fenders from 34-35 high cab would work .. gives me more options when searching .. great info thanks
Y
yar Offline
Y Offline
Dawg, are you talking about a "correct" restoration or simply what will fit. I have a '36 high cab pickup that I have owned since 1965. It has been a stock beater, street rod and is now restored to original.
I'm presently converting its 4.11 rear gear ratio to 3.55 using OEM chevy parts.
Ray
