| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 9 New Guy | | New Guy Joined: Oct 2009 Posts: 9 | what year body parts will work with the 36. the 34-35 high cab grill ,fenders look the same . im trying to spread my search . the 37 hood looks the same. has any one used these different years on a 36 . thanks | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Are you talking about a "high cab" 36, or a "low cab" 36? Some 34-35 "high cab" parts will interchange with a 36 "high cab". The " low cab" 36 shares some parts of the cab with the 37-38. Most cab parts can interchange except the windshield and interior door panels. The rest of the truck will not interchange with the 37-38. The 36 "low cab" has some wood in it, the 37-38 have no wood. The 34-35 "high cab" trucks have a good amount of wood in them.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | If I recall correctly you have a lowcab. From what I've seen 34-35 fenders and grill will work. As far as the cab goes the post above is accurate. I'm using a 37 cab on mine. | | | | | Joined: Oct 2009 Posts: 9 New Guy | | New Guy Joined: Oct 2009 Posts: 9 | yes i have a low cab .. and was wondering if the grill and fenders from 34-35 high cab would work .. gives me more options when searching .. great info thanks | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Dawg, are you talking about a "correct" restoration or simply what will fit. I have a '36 high cab pickup that I have owned since 1965. It has been a stock beater, street rod and is now restored to original.
I'm presently converting its 4.11 rear gear ratio to 3.55 using OEM chevy parts.
Ray
