| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63810 08/03/2006 5:05 AM | Joined: Aug 2006 Posts: 4 Junior Member | | Junior Member Joined: Aug 2006 Posts: 4 | the sm465 transmission in my truck is having troubles. the shifter has tore up. i was wondering if anybody has experienced this type of problems and if so what did they do. i wasnt driving when it broke so i dont know exaclty what happened, i took it mud bogging then i let somebody borrow it and it broke then. the shifter just moves around freely, i can get it in to 1,2,and 3 but not low or reverse. it seems like there is some sort of linkage or somethin broke. i have had the entire body off the truck and was unable to get the shifter out, tried to push it down and twist but it didnt work. is there a way to get into the transmission other then tearing the entire cover off. thanks for any ideas, by the way its out of an 84, i dont have a pre 73 but i sure would like to have a 67 or so. | | |
#63811 08/03/2006 9:48 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have to have the trans halfway in reverse for the cover to lift out. It does present a problem being you can,t shift to reverse. Have you taken the lever out of the cover yet. You press down on the collar with pliers 7 turn it counter-clocwise about 30 degrees. You might find the problem there or be able to shift partway into reverse with a big screwdriver. Those are tough tranny,s. They are hard to work on but I think you will know a lot about it before long. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63812 08/03/2006 10:45 PM | Joined: Aug 2006 Posts: 4 Junior Member | | Junior Member Joined: Aug 2006 Posts: 4 | thanks ill try it, the truck was stole and burnt a year and a half ago, then we spent about 10 months fixing it. we have put a new rearend in it, clutch, lots of wiring and many other parts. i thought the transmission would be the last thing i would break. i just bought a sand rail that needs a lot of work so im kinda pressed for money hopefully it want cost too much. | | |
#63813 08/05/2006 6:49 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It's really not that bad to take the top cover off one of these transmissions. You just have to make sure the shift forks align when you put it back on.
