| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | I was wondering if someone could shed some light on me as far as the screws that hold down the center floor pan on the 53 3100s is there a special bit for them or do you just use a regular screw driver to get them off ? As you know they are the shape of a reg screw driver just wider. Thanks | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | i think your looking for a clutchhead screw driver least thats the name i am familiar with
1937 1/2 ton
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | if his truck is the same as my 59 the screws will have an hourglass shape and standard slot driver will have a hard time griping them
1937 1/2 ton
| | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Ok guys I guess I will buy a clutch head screwdriver that is the proper size. Thank you all for the info.And thanks for letting me know that there is no reg screwdriver all these years I thought there was a phillips and reg head driver.
Thanks again | | |
