1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Has any one restored a 1969 Chevy C50 and replaced the rubber floor?
Certainly someone has replaced the floor mat. What is your question?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I haven't had any luck in finding a flat floormat for my 1964 GMC 4000. I might get one for a low hump pickup and have to cut it and bond it back together. The transmission bump is about 1 3/8 inches high at the tallest part.
there is no "flat" floor for the 67-72, you either have a low hump [3 speed/small trans] or a high hump [4 speed/large trans] - see here [same goes for the 64 if that's the correct year, and for the previous 55-59's as well]
Those are for pickups. A 4000 is a 2 ton truck, the body sits much higher above the engine and transmission. His C50 is a big bolt also. All the GMC and Chevy medium duty trucks from 60s and 70s that I drove had an almost flat floor. A straightedge across the transmission cover on my 4000 is only 1 3/8 inches above the floor level. Here is the previous discussion on it: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=543399&page=2
Some pics of big bolt floor: http://rides.webshots.com/photo/2930912880104602464raUYFU
