| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 44 | My wife was driving the truck and I noticed that the brake lights came on but then almost immediately went off. We checked the brake line and all is well...When we first touch the brake and press down to stop the lights come on and stay on...but if you press down real hard they turn off. Any insights on where to start on this issue would be appreciated. 46Trucker Craig
Craig 1946 Chevy Mod Truck
| | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | 46Trucker,
If memory serves me correct, the 1941-46 trucks have different types of brake light switches. 1941 has a hydraulically activated sensor that mounts directly (plumbed) into the master cylinder, and 1942-1946, they went to a mechanically activated switch that attaches to the toeboard inside the engine compartment. You also mentioned that you checked the “brake line”. Are you referring to the wires or the hydraulic brake lines? My first guess would be to check the switch with a volt meter, while taking your reading, see if you can duplicate your problem while stepping on the brake. If so, then the problem could be your switch. If unable to duplicate at the switch, then it must be between the switch and the taillights. Hope this helps,
Dale
| | | | | Joined: Dec 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 44 | Dale Thank you for your insightful reply..I will check the switch on Saturday...when I referred to the brake lines I ment the wires...they are all connected and clean... Again Thanks Craig
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | 99% chance its the stop light switch. About six or eight bucks at any of the vendors and two screws holding it in place. DG
Denny G Sandwich, IL
