3 members (klhansen, dt235sd, 1 invisible), 67 guests, and 0 robots.
Topics128,049
Posts1,055,679
#637760 04/15/2010 1:43 AM
I'm replacing the fuel system on my 1946 2 ton and am not sure whether it takes a single or a double action fuel pump, any input is helpful.
Thanks, Emory
the 2nd ammendment is in place incase the politicians ignore all the others
ELieber #637776 04/15/2010 2:55 AM
Either one will most likely work.
The single action pump was most likely standard/stock.
The dual-action pump was an option/accessory to provide better movement of the windshield wipers.
Yes, the single-action pump was standard. If the truck originally had a double-action pump that was replaced with a single-action unit, you should find extra vacuum lines that would have connected to the pump, and probably the wiper motor.
Harvester
