1 members (Forty9), 66 guests, and 1 robot.
Topics128,055
Posts1,055,782
#637642 04/14/2010 7:01 PM
At some point I would like to upgrade the tranny and drive line of my 1954 Chevy 3100. To keep the closed system I would need:
Patrick's rear end gears (3.55) $400
Patrick's rear rebuild kit $300
Patrick's Saginaw trans conversion $460
Saginaw 4 speed (3.11) $600
About $2k probably when finished.
Is the cost for an open drive line with overdrive about the same?
Not having done this myself I can only guess but I certainly think that a wrecking yard diff, tranny and driveshaft would be a lot less. Your figures make no assumption for labor so I guess it's a DYI?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
DIY unless welding comes into play. Bolt on stuff I can do. I must pay for welding to be done.
A '55-'62 1/2 ton center section will bolt into your housing.
That will get you open drive line with 3.90 gears.
A T5 overdrive 5 speed transmission out of an S10 can be used with minor mods. Both of these swaps I believe are in the tech tips section here.
You will also need to have a driveshaft made, or use a junkyard driveshaft if you can find one the right length.
Steve
'49 3800
'52 3600
'57 3100
Putting in the 55-62 pumpkin does not solve the open driveline problem. Welding is still required. A possible bolt on deal is to find a 55 first series truck and use that housing with the 55 first springs. you will have a choice of several transmissions to fit the open drive.
On my 59 gmc, I just changed the rearend. The cost was more than I would care to post. Not being able to weld myself set the price through the roof.
So a few of donors are available cheap. 57 and 55 2nd. Quick recap of welding involved?
