0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | mine has one of the bolt where the donut gasket is on the pipe broken. Can you still get new manifolds. What have others done to fix it. Thanks Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | First, welcome to the Stovebolt. This is a good place to get your answers.
For your manifold, it is best to remove it and remove the broken stud on the bench. Some will use heat for the job and others will just very carefully drill out the center and use a punch to remove what remains. A good machine shop can do this for you. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you want a replacement try the Truck Parts for Sale forum. I'm sure it won't be hard to find one. | | |
