2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
Apprentice
Apprentice
Can it be done? I saw a thread on the HAMB
(I think) where a guy repositioned the front springs to lower a 55 and later truck.
I have a 49 Panel and am wondering about this idea.
Seems any type of lowering is costly.
Opinions ?
Someone here in the UK has done this to an AD truck. The biggest issue with this modification was that there was very little suspension movement left with the front axle mounted on top of the spring. IIRC, there were clearance issues with the track rod to the springs also.
To avoid having huge amounts of bump steer with this setup, you will also need to move the steering gearbox up on the chassis so that the drag link is still parallel to the ground at your truck's "normal" ride height.
If I was going to lower my truck, I think I would use one of the stretched lowered straight axles instead.
Good luck with your truck, Stuart.
the best way to lower a straight axle is to get a dropped axle by Sid. http://www.droppedaxles.com/ PERIOD!
