4 members (Gdads51, chemanic, Joe H, Phak1), 83 guests, and 2 robots.
Topics128,101
Posts1,056,339
Members48,441
#63718 08/01/2006 5:33 AM
Junior Member
Junior Member
My 65 stepside has a valve nock that goes away after a while. I am contemplating pulling the head and reworking it. I may pull it and simply lap the valves and readjust after cleaning.
Can I still purchase springs and keepers if need?
Is this something I should leave as is or should I break it and then fix it.
steve
[email protected]
O BLUE has 99,000 original miles
#63719 08/01/2006 2:33 PM
I'm not sure what you call a valve knock, lifter adjustment. Here's a link to adjusting lifters
http://www.centuryperformance.com/valveadjustment.asp
I'd run a compression ceck and leak down check before considering a valve job. The keepers and springs are still available they are the same as a SBC.
Larry
I don't own a vehicle that isn't old enough to drink.
#63720 08/01/2006 4:44 PM
I agree with LGriffin. If You decide the head does need reworking, always, always install new keepers.
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
