0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#636969 04/12/2010 4:09 PM
Probably obvious question for most but not for me. I have my 1950 1/2 stock. It has the original 216 with the 3 speed on the tree. The engine runs great but it won't go into gear! It doesn't grind as and when I push in the clutch, put it in gear, and then let off on the clutch, NOTHING! It feels like there is nothing spinning in the clutch to get it in gear. I am not familiar with how it all works and I'm of course hoping for some easy clutch repair part rather than thinking the tranny is bad. Thanks for any help!
Stranded
Is the NOTHING the same in all gears? If you take the floor pan out there is a clutch inspection plate on the bell housing held on by two screws. You can also pull the dust shield underneath and look for scattered clutch parts.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Yes, this happens (or doesn't happen) in all gears. I took off the bottom plate and didn't see anything obvious. I will look at the inspection plate through the floorboard. Am I looking for anything in particular?
Since you already have the bottom shield off, have some body depress the clutch and look at the disk. It should have approximate equal material on both sides at 1/8" to 1/4" thick. Since you can shift into gear with the engine running I suspect the problem is not the clutch.
1953 Chevrolet 3600
