5 members (51sub, walter74, Gdads51, MickeyP, Chip O), 67 guests, and 2 robots.
Topics128,041
Posts1,055,593
#636655 04/11/2010 9:22 AM
B46
Offline
I've been looking but can't find anything.
There are the air inflated shocks inside the rear springs on my truck. They gave an inflator valve on them with an extention that leads the rear fender with another inflation valve like that on a bike. Can someone explain this to me. How did it work? Were you supposed to inflate to your preferences? Thanks.
Brandon
1988 4Runner: SR5 ~ 3.0 ~ 5-Speed ~ No Sway Bar ~ 3-Point Rear Seatbelts ~ KC Daylighters ~ EGR By-Pass
1946 Stovebolt: Rebuilt 216 ~ 6V ~ All Stock
Extras: Stuff for my signature that just wouldn't fit.
B46 #636698 04/11/2010 3:44 PM
They are for leveling the truck when you have a heavy load in it. You know how the back end sags with a bunch of gravel or something in there? You put air in the shocks until the truck sits right. It increases the amount of weight you can carry. Sometimes people use them to level the vehicle empty too if one of the springs is sagging...Its pretty handy, I'm planning on putting a set in my '70 Ford (boo boo hiss hiss, I know).
ErikDaViking #636711 04/11/2010 4:26 PM
I have a set on my '53, they were there when I got the truck. I had a set on my '77 El Camino that allowed me to raise or lower the rear end about a foot when empty. With full air pressure and an empty box the back tires would bounce off the ground when I hit the brakes.
twotone #636762 04/11/2010 9:48 PM
Brandon, In the pics of your 46, looks like air bags inside coils under the 46. Most common are actual shocks that you can inflate when needed. Never seen ones like your 'air bags' but if it works they are really handy.
1946 1/2-Ton Chevy
Brandon, I would think the 'helper' springs are almost certainly a later add-on.
As Erik mentions they inflate to increase the load capacity and to assist levelling.
I'm sure i've seen them for sale recently.
I do know AirRide Technologies sell a similar set-up but without the coil.
More pix on Flickr.
jockbolter50 #636874 04/12/2010 6:54 AM
B46
Offline
Thanks guys. That does make sense now. I just wasn't sure if they were stock or not. I've seen the coils added before to soften the ride, just haven't seen it with the air shocks.
Well the passenger side shock is torn open; old rubber. But the driver's side one inflates and holds. Makes that side of the rear end higher, so I for sure realize its purpose now.
Brandon
B46 #636955 04/12/2010 3:28 PM
Brandon,The Brand name of your air bags may be"Airlift"they've been around a long time.Still are.
