Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (baldeagle, kades51, IHPWR, Southerntruck, farmallb, JW51), 65 guests, and 3 robots.
Topics128,005
Posts1,055,264
Members48,418
#636695 04/11/2010 3:39 PM
I’m currently rebuilding my ’53 power glide 235. In the process we found the original head had 9 different cracks, so I purchased a ’60 head which now has been fitted with new valves, guides and hardened seats. I’m wondering if this later head will raise my compression ratio from the ’53 spec. of 7.5 to 1 to the ‘60 spec. of 8.25 to 1
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Yes, the newer head will raise the compression ratio. If the casting number ends in "848", that's the best possible head to run on a 235, compression-wise. You might need to adjust the ignition timing to the later engine's specifications to take full advantage of the compression change.
Thanks Jerry.
Yes the timing will be an adventure. The engine including cam and distributor are '53PG, and the flywheel is a '41. No telling where to set the "ball". I did check before I put the head on and found TDC. Using a little math the ball looks to be about 5 degrees before TDC. I plan to start there and slowly advance till I get a little ping when pulling hard in top gear
Yup - that's better than the factory setting IMHO.
