0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63641 07/30/2006 1:25 AM | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I only drive my truck on weekends. After driving for awhile it will start to idle very rough. If I turn it off and let it cool down, the truck will start right up and run great. Then it’s the same thing all over again. I don’t smell any gas as if its flooding. I’ve noticed lately some condensation on the base of the carb just above the insulator. It doesn't smell like gas. My vacuum gauge reads low on the intake manifold. So far I haven’t found any vacuum leaks using carburetor spray. The engine has never been rebuilt. It’s old but usually always starts up without a problem. I’ve thought about buying a carburetor rebuild kit. The carburetor doesn’t have any identifying numbers to tell me which Rochester B that I have. So buying the correct rebuild kit might be difficult. http://i7.tinypic.com/21czh8i.jpg http://i7.tinypic.com/21d04ly.jpg Are the rebuild kits somewhat universal for the Rochester B? Is it very difficult to rebuild for a novice? Do you think the problem could be something other than the carb? I’m hoping someone can point me in the right direction. Many thanks. Mark | | |
#63642 07/30/2006 1:37 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I can't speak fpr other brands, but the Standard/Blue Streak brand carb kits usually will cover all varients of a given carb model. They also include a guide of the numbers and where to find it on the carb so you can ID it. I don't think taht the Rochester B is too difficult to overhaul. You may want to check around the manifold ports for vacuum leaks, and the line to the advance too. Could have a bad gasket. By the way, what is that peice that is welded to the carb top?
Bill Burmeister | | |
#63643 07/30/2006 3:12 AM | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'll check around for leaks again and loose fittings. A bad gasket might be a good call since it has been moist at the base. The air filter sits on the ring that is welded on the carb. It was on there when I bought the truck a few years ago. I'm not sure if it was an add-on or if a previous owner bought it that way. Jim Carter sells a Zenith with the same ridge. http://www.oldchevytrucks.biz/catalog2/0105.html Mark | | |
#63644 07/30/2006 3:24 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Interesting. It must have been added some where along the way. I know that the original filter doesn't mount that way. Perhaps you have a filter for a different application.
#63645 07/30/2006 3:27 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That looks like the standard carb for that era. Any parts place can supply a kit by application. They are really easy to rebuild. Like Longbox posted it could be sucking air around the ports where the manifolds go to the head. Try tightening the bolts. I wonder how someone welded that pot metal like that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63646 07/30/2006 11:17 PM | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'll try tightening everything around the manifold and hope for the best. I'm going to go ahead and buy the carb rebuild kit.
Regarding the weld on the carb. I'm not sure if the previous owner did that or purchased the carb that way. It looks weird but it holds the aircleaner on the top well.
Thanks. | | |
#63647 07/31/2006 12:56 AM | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Mark,
Your carb looks pretty good from the pics above. Based on the description of your problem, it sounds as if the idle is a little low. I know my truck idles high when I first start it, but after it heats up the idle calms to a dull roar.
Adjust your idle screw a little and give it a try before you get the rebuild kit.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
#63648 07/31/2006 1:38 AM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Also check the exhaust manifold heat valve and spring. Make sure the shaft is free and not sticking in the manifold.
To check the spring, unhook it from the anchor pin. Proper adjustment requires only 1/2 turn of the spring, from its unhooked position to slip it over the anchor pin.
-Tom
1950 Chevy 3100 w/ 1956 235
#63649 07/31/2006 2:27 AM | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Is the exhaust manifold heat valve located just before the point where the exhaust manifold meets the exhaust pipe? I see a valve that is always in the open position.
I checked the tightness of the bolts from the manifold to the head. I re-tightened the carb to the intake manifold and adjusted the idle mixture.
It runs good but I hear a whistling noise that increases with rpm. Its not the fan belt. It sounds as if its coming from the carb. Could that be? | | |
#63650 07/31/2006 2:37 AM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I suffered with similar symptoms...Rochester 1bbls! They do have a tendency to load up when they get warm...one solution...put an adjustable fuel pressure regulator between the fuel pump and the carb,,,dial it down to about 4.5 to 6.0 lbs psi. | | |
#63651 07/31/2006 6:05 AM | Joined: Jul 2006 Posts: 58 Member | | Member Joined: Jul 2006 Posts: 58 | Back to the possibility of a vaccuum leak, don't forget the line to the transmission if it is an automatic!
1967 Chevy truck "The Hurricane"
WARNING: This suspect has a tendency to jerry-rig.
"My engine ain't fast, but I pulled a tree trunk out of the ground once."
#63652 08/01/2006 4:22 AM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | I just bought a 65 with the 292 6 cyl. It had all sorts of gas leak around carb. Based on the time I did not have and the cost (99 + core) of a rebuild 1 barrel, I opted to change the whole thing and glad I did. I put a new insulator on it hooked up choke cable and tightened it down. One air mix screw to adjust and the idle. Very simple took maybe 30 minutes. I have not put a tach on it yet but adjusted it by smoke and just what sounded right. Runs great made a huge differenc. | | |
