4 members (walter74, Bisbee, Rusty Rod, UtahYork), 105 guests, and 3 robots.
Topics128,089
Posts1,056,437
Members48,443
I just came out of my garage after removing 50+- trim screws from my 41 gmc door panels. As every one has experienced this can be a real b----. my solution was to take care of the easy ones then to switct to heat. Get your heat gun and set it right on the screw for 2-4 minutes then quickly put your screw driver into the slot and really pound it and then start breaking with forward and then reverse direction. What is happening is that you are burning rust with the heat and also making a new seat for the rusted heads of the screw. Try it, it works and you do not need "blaster" but you probably won't use the screws again either. It is a little slow but you will not be drilling out old screws. If it doesn't work the first time just turn up the heat and repeat. doug
I took my dremel tool to mine, I took a very thin cutoff wheel and cut about a third of the head off, then cut another third of the opposite side, then took vise grips to it. I removed almost 2/3 of the screws on doors and cab this way, never drilled one, got them all. I tried heat, used a propane torch, cutoff worked way better. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
